Aug 17th, 2024, 6:15am
input impedance of voltage multiplier (Read 4628 times)
sriniv1422
Aug 18th, 2006, 7:16am
Hi all ,
Iam trying to simulate the  Modified Greinacher voltage multiplier circuit( capacitor-diode series ) for RFID tags. This is being used for Livestock IDentification.
The specs are as follows:
load current: 50uA
input power : 600uW.@50ohm.
Iam using a  matching network followed buy a two stage mulyiplier circuit.
Iam trying to calculate the input impedace of the voltage multiplier ciruit , so that I can design the matching network.
could you please let me know ,  what simulation techniques  could be used to estimate the  real and imaginary part of the input impedance.
I have tried injecting an AC current and measuing the voltage  .But these give me wrong results.
Could you please let me know , how to set up the simulation ,  so that input impedance can be calculated  after the circuit has reached steady state.
I would really appreciate any info regarding this.
thanks
srinivasan.
gmadhavareddy
Re: input impedance of voltage multiplier
Reply #1 - Sep 11th, 2006, 1:03pm
I am also doing the same type of analysis. I also not geting proper results with schottky diodes with standard specifications.
We can solve only with proper schottky diodes(means well modeled)
Bye
Madhav
gmadhavareddy
Reply #2 - Sep 13th, 2006, 5:36am
Hi Srinivasan,
I am also doing thesis on same project. I want to discuss with you some other things realted to input impedance.
Could u give your contact?( mail id or phone no)
Madhav
gmadhavareddy
Reply #3 - Sep 13th, 2006, 9:40am
I dont know exactly wich simulator u r using. I asked my supervisor may be it will help u.
U have to do large signal transient analysis for calculating input impedance.
Zin(1harmonic)= Vin(1st harmonic)/Iin(1 st harmonic).
I want to know wether u r using schottky diodes for votage multiplier or it is sufficient for Ordinary MOS transistor?
Madhav
Reply #4 - Sep 13th, 2006, 10:23am
If you use Spectre, you can use its "Fourier Analyzer" to do this calculation for you. Use "spectre -h fourier" and specify both sets of inputs.
sriniv1422
Reply #5 - Sep 14th, 2006, 2:19pm
ken
thank you. i will try this out.
srinivasan
