Thanks for all the replies.
I'm able to run noise sims now
![Cheesy Cheesy](https://designers-guide.org/forum/Templates/Forum/default/cheesy.gif)
, and I got the integrated output noise by Results->Direct Plot-> Output Equivalent Noise, later I clicked wave from calculator and print "sqr(integ(wavew10s1il()**2,10,100k)).
My problem now is :
I need to get the noise expression and put it in the "Setting Outputs" so that I can do Monte Carlo sim. However, as you can see, it would have a problem with the "wave" parameter. How can I put the noise expression into the calc then ?
Richard :)
