Aug 23rd, 2024, 5:16pm
opamp for ldo (Read 10717 times)
grosser
opamp for ldo
Aug 22nd, 2006, 6:23am
hello
Can you recommend an opamp for LDO regulator which is suitable to work under low voltage (Vin=1V-3.3V)?
if you have, upload the schematics please
regards
Re: opamp for ldo
Reply #1 - Aug 22nd, 2006, 7:50am
two questions -
Input voltage range?
What are you driving for a load?
Jerry
grosser
Re: opamp for ldo
Reply #2 - Aug 22nd, 2006, 9:04am
loose-electron wrote on Aug 22nd, 2006, 7:50am:
two questions -
Jerry
input range 1V-3.3V
Iload 1mA-100mA
Re: opamp for ldo
Reply #3 - Aug 23rd, 2006, 8:25am
That large an output current, you will need a source follower type buffer for an output driver.
Also, your input voltage is not going down to ground so a NMOS differential pair input should work.
Add an NMOS source follower to the attached and it should get the job done. The compensation here uses pole splitting, there are other options as well.
Visjnoe
Re: opamp for ldo
Reply #4 - Aug 23rd, 2006, 10:55am
I would just like to comment on the OTA topology given above and note that:
1. It has a certain systematic offset, which might be kept low enough if you have enough gain in the first stage.
2. It has a very bad PSRR. Insert a cascode to improve this.
Kind Regards
Peter
Re: opamp for ldo
Reply #5 - Aug 23rd, 2006, 6:35pm
cascode will help with the PSRR a bit yes, agreed.
The systematic offset will probably be overshadowed by the differential pair mismatch.
An LDO usually ends up getting trimmed (usually the bandgap reference) to get to the right operating point output, so that should fall out of the equation.
grosser
Re: opamp for ldo
Reply #6 - Aug 24th, 2006, 12:36am
hi
i have tried this simple topology, but it is not enough because of the source follower.
For the lowest Vin=1V it can drive the full load (100mA) but can't drive low load current.
I'm looking for something with simple architecture and good slew-rate current.
regards
Re: opamp for ldo
Reply #7 - Aug 24th, 2006, 10:07am
grosser -
Not sure exactly what the problem is, if you could define the problem a bit more perhaps I can help.
Jerry
grosser
Re: opamp for ldo
Reply #8 - Aug 24th, 2006, 1:18pm
loose-electron wrote on Aug 24th, 2006, 10:07am:
grosser -
Jerry
the problem is that for low input Voltage=1V when i use source follower with nmos input opamp can drive large load, but can't drive low load and can't shutt off when it's needed.
When i use source follower with pmos input i can't drive large load.
i know this topology is not suitable for low voltage and i want to check other possibilities.
richard88
Re: opamp for ldo
Reply #9 - Aug 24th, 2006, 10:02pm
grosser,
 I think you have to specify more info for an LDO :
 What is your VIN (or VDD), Vref, Vout ? is the feedback factor=1 (no resistor divider, direct feedback) ?
Richard
Re: opamp for ldo
Reply #10 - Aug 25th, 2006, 8:40am
Ah, if that is the case, you can use an OTA type output, with lots of gain. You do this in a Class-AB type structure with a PMOS and NMOS outputs being controlled. With lots of gain it give the capability for either the PMOS or NMOS output to be driven triode.
That will get your control for the PMOS power transistor to go from ground to power (or pretty bloody close)
in concept (sorry dont have a picture)
2 NMOS differential pairs
2 current mirror structures above the differential pairs
opposite polarity on the high gain output of each differential pair
one output drives the PMOS output of the OTA
other output drives a PMOS current source, that mirrors into a NMOS (diode connected) which drives the NMOS output of the OTA.
There are other ways of doing this as well, with one differential pair, and you may need additional gain before getting to the NMOS/PMOS outputs.
The key thing is the A/B output stage.
Jerry
