Aug 23rd, 2024, 11:20am
Power down simulation (Read 5407 times)
sck236
Aug 29th, 2006, 3:28am
In power down(shutdown) mode,
I want to see if the circuit has no floating nodes which might cause leakage current.
How can I do this simulation in spectre?
Just apply power down signal and watch the current out of the power supply?
If the current goes down near to zero, is it safe for leakage current?
and does it also mean there is no floating nodes?
In my opinion, even if there is no leakage current, there could be a floating node of which potential is zero.
I think this node may have leakage problem in a real circuit. Am I correct?
Thanks in advance.
ACWWong
Oxford, UK
Re: Power down simulation
Reply #1 - Aug 29th, 2006, 4:33am
Hi sck326,
Please see my comments/opinions, i hope they help:
sck236 wrote on Aug 29th, 2006, 3:28am:
Yes, just applying the power down signals in a simulation should be fine. What is a tell tale sign of floating nodes, is the time it takes for the current to discharge to zero (or the DC value in power down) when one does a transient rather than DC simulation.
Yes, assuming you have captured any non-schematic effects such as layout only devices like antenna diodes and alike.
Agreed
Again if you capture all the layout devices, and have good models, you should NOT have a leakage problem.
cheers
aw
Reply #2 - Aug 29th, 2006, 9:43am
Power cycling, -- having been severely bit by this one ---
Suggest - simulating of power cycles often does not account for all the parasitic capacitances in the system, and a floating gate of a transistor is unpredictable in what it is going to do.
Suggest - If you are in PD mode, every single NMOS current source gate should be yanked to ground, and every single PMOS current source gate should be yanked to power rail. Also any and all current paths need to be defined as solidly switched off, using some form of a switch. No opening the circuit and letting it float down to ground as it discharges.
Been there, done that, gotten bitten, had to respin the chip.
uncle_ezra
Reply #3 - Aug 29th, 2006, 5:47pm
As a sanity check do a transient simulation with power supply going from high to low. This will most of the time give a different result than a simple DC analysis and it is also closer to reality.
sck236
Reply #4 - Aug 29th, 2006, 11:40pm
loose-electron wrote on Aug 29th, 2006, 9:43am:
Power cycling, -- having been severely bit by this one ---.
What does "respin the chip" mean?  ::)
Is there any rule of thub to determine the size of the switch which yanks the gate to ground or power rail?
Reply #5 - Aug 30th, 2006, 8:35am
Switch size? - generally min channel length, and some width that fits into your layout works.
As suggested above, doing some transient sims of power cyling is very valuable, power supply up-down, turning the PD control on-off at various times, having glitchy power on-off (switch contact bounce issues) will help you determine what is needed as part of power cycling.
Jerry
PS - respin = a "learning experience"
Grin
uncle_ezra
Reply #6 - Aug 30th, 2006, 8:36pm
One more thing sometimes using minimum length can cause large leakage at some corners particularly if you are using core devices. So if at some corner the leakage is large try longer length device. I guess this is more pronounced for 0.18um and below.
Reply #7 - Aug 31st, 2006, 12:35pm
Leakage issues exist from about 0.35 and down. People did not start noticing them until they bacama a major issue (90nm? or thereabouts)
If leakage is a question, simulate at the hottest die temperature, where leakage is generally the worst.
