littlekoala
Hi, there,
I am trying to model and simulate PLL jitter with the voltage-domain method introduced in Kundert's paper on the designer-guide website.
But I get a compiler error from the Cadence Verilog-A compiler, which says that the system function $dist_normal can not be included in the analog block. The original error message is as follows:
[AMS semcheck]: Error # SEM741: Digital or unknown system function '$dist_normal' found in analog block.
The tool is Cadence ICFB Version 5.1.0.
Can anybody help me out with this problm?
Thank you very much.
Littlekoala
