Jul 16th, 2024, 1:44pm
Compiler Error of Verilog-A in Cadence-$dist_norm (Read 202 times)
littlekoala
Aug 30th, 2006, 9:22pm
Hi, there,
I am trying to model and simulate PLL jitter with the voltage-domain method introduced in Kundert's paper on the designer-guide website.
But I get a compiler error from the Cadence Verilog-A compiler, which says that the system function $dist_normal can not be included in the analog block. The original error message is as follows:
[AMS semcheck]: Error # SEM741: Digital or unknown system function '$dist_normal' found in analog block.
The tool is Cadence ICFB Version 5.1.0.
Can anybody help me out with this problm?
Thank you very much.
Littlekoala
Re: Compiler Error of Verilog-A in Cadence-$dist_n
Reply #1 - Aug 30th, 2006, 10:22pm
Use $rdist_normal(). $dist_nomal() returns an integer and can only be used in a digital context, $rdist_normal() returns a real and can only be used in an analog context.
jbdavid
Reply #2 - Aug 30th, 2006, 10:42pm
I can't find any reference to $dist_normal in the 2.2 version of the LRM..
may be you can talk Ken into updating his papers to use $rdist_normal which is found..
$dist_normal existed in the Verilog spec first and the verilog-A used with spectre ALSO has to work with AMS designer which conforms to the 2.2 spec (mostly)..
jonathan
jbdavid
Reply #3 - Aug 30th, 2006, 11:13pm
$dist_normal() was the name used by the standard some time ago, but then it was changed to $rdist_normal() when it was discovered that the analog version returned a real and the digital version returned an integer.
I have updated my paper to use $rdist_normal().
Thanks for pointing out this issue.
