ACWWong
I don' think you need to import it. Using the Analog design environment, you simply include the .scs file in the model path (In ADE->Setup->Model Libraries). Then in your testbench you instantiate a component with the right terminals which reads that model file... Anyway I guess the .scs file is just a netlist of lumped components and values, from which it should be easy to create a schematic view.
