grosser
hello again
Sorry for so many questions about LDO.
I want to use LDO with buffer configuration.
For my spec Vin=1.3V Vref=0.8V i can't use simple source follower with NMOS or PMOS input.
I thought about using ompamp in buffer configuration, but it also is not enough, because for high load, power transistor's gate is low and buffer's input transistor are off.
I don't want to use a rail to rail configuration. What else can i do?
regards
