Aug 17th, 2024, 12:30am
Error Message in Charge Pump Noise Simulation (Read 2054 times)
timmc6
Sep 05th, 2006, 9:29am
When simulating the phase noise of my charge pump using PSS/PNOISE, I am seeing an error message saying "Relative residual of linear system is significantly above tolerance.  Results may be inaccurate."  The message occurs for frequency steps between 100Hz and 500Hz, then does not appear for the higher frequency steps.  Has anyone seen this error message before?  Thanks.
Tim
Re: Error Message in Charge Pump Noise Simulation
Reply #1 - Sep 5th, 2006, 11:10am
This is one you probably want to show Cadence.
