Aug 16th, 2024, 8:55am
Which one is better from the jitter point (Read 2547 times)
dandelion
Sep 05th, 2006, 7:26pm
Pls. take a look at the attached diagram. It is in fact a mixed mode circui which amplified a weak signal and buffer it to a digital CMOS/TTL level. The only descrapancy of two figures are the cascaded amp satge, two stage versus four stage.Except the numbers of stages, all others are same, the amp stage is same,buffer is same and the laod cap is same also.
The transient analysis show that these two topology gave the same output signal, i.e.,the rise/fall time,duty cycles etc...
But I have some concern on the jitter performance, because I did it with transient analysis, I can not evaluate the noise performance. What do you think which one gives the better jitter performance?
My opnion is the Fig.2 would have better jitter performance. That's because , the SNR from Fig.2 at the output from the fourth amp stage is better than that from output of second samp satge of Fig.1.
Pls. comments.
Re: Which one is better from the jitter point
Reply #1 - Sep 6th, 2006, 1:59am
John,
I prefer Figure 1, because it achieves the same output (rising/falling time) using only 2 amps and one buffer. I think it is digital output, so SNR is not a problem. The less amps/buffers introduce less thermal noise and switching-induced jitter.
Best regards,
Yawei
Reply #2 - Sep 12th, 2006, 1:21pm
This is something that you could use the "jitter" (or "timedomain" - aka "strobed") noise mode of SpectreRF's pnoise analysis to investigate. Of course, if you don't have SpectreRF, you can't  :'(
