kiran123 wrote on Sep 5th, 2006, 11:46pm:1) what is the operating region of both transistors (NMOS and PMOS)
I would say both transistors are in strong inversion (and in the linear region). The channels will conduct (at least slightly, initially, and then better as time goes on) such that the gate of the NMOS will eventually be pulled up to VDD and the gate of the PMOS will be pulled down to VSS.
Once the gates have settled out, the channel resistances will be small, and you can probably ignore them when computing the capacitance, which will simply be the total gate capacitance (cgs+cgd+cgb, including overlap caps) for the two devices.
