aamar
I get this problem when I try to run the pss analysis :(
Fatal error found by Spectre at time = 35.6759us during periodic steady state analysis 'pss' Insufficient memory available.
I am not sure that it is a memory problem because i think I am working on a strong enough machine, so shall I contact the system administrator or is there another solution for this problem?.
Thanks in advance.
aamar
