Jul 19th, 2024, 10:18am
power transitor leakage (Read 3502 times)
grosser
Sep 06th, 2006, 5:16am
hello
i mean about LDO circuit again
how can i decrease power transistor's (PMOS) leakage under 5uA and under what conditions i should measure it?
I do that with the lowest Vdd and no load in every process corner.
Trasnsitor has to be large to drive 100mA load under 1.3V so i cannot decrease its width much. It's 15mm wide nad 0.35um
regards
Re:  power transitor leakage
Reply #1 - Sep 6th, 2006, 9:11am
Hey there:
Leakage tends to be worse at higher temperatures, so I would go to your hot corner, and start by looking there.
If this is gate leakage, and getting to zero leakage is important to you, you may want to consider using the I/O transistors, usually higher threshold voltage but thicker gate oxides and less leakage.
Jerry
grosser
Reply #2 - Sep 6th, 2006, 9:17am
loose-electron wrote on Sep 6th, 2006, 9:11am:
Hey there:
Jerry
isn't that drain current under no load conditions??
Reply #3 - Sep 7th, 2006, 9:05am
You have several different mechanisms happening here. If I remember correctly they all get worse at higher temperatures.
Raul
San Jose, CA.
Reply #4 - Oct 10th, 2006, 2:34pm
Power transistor leakage will be worse under fast-P(for PMOS LDO) corner and hot. Design wise all you can do is to design a circuit that under no-load conditions will drive the gate of the PMOS all the way to supply(at least within 60 mV of the supply rail given the device in sub-threshold conduction). Some people go through the trouble of building a charge pump and connecting the body of the pmos to a voltage that is higher than the supply to increase the VT of the PMOS with the body effect. This will inject noise to the output of the LDO and cost you caps for the charge pump which doesn't really need to drive much current at all.
There is really nothing else you can do circuit wise since this is a device physics problem. Everyone has this problem, talk to the fab and see what they can do for you.
regards, Raul Perez
