![](https://designers-guide.org/forum/avatars/fredflinstone.gif)
Best Design Tool = Capable Designers
Hey there:
Leakage tends to be worse at higher temperatures, so I would go to your hot corner, and start by looking there.
If this is gate leakage, and getting to zero leakage is important to you, you may want to consider using the I/O transistors, usually higher threshold voltage but thicker gate oxides and less leakage.
Jerry
