Jul 21st, 2024, 8:31pm
Insufficient memory by PSS analysis (Read 2365 times)
aamar
Sep 06th, 2006, 6:23am
I get this problem when I try to run the pss analysis  :(
Fatal error found by Spectre at time = 35.6759us during periodic steady state analysis 'pss'
Insufficient memory available.
I am not sure that it is a memory problem because i think I am working on a strong enough machine, so shall I contact the system administrator or is there another solution for this problem?.
Thanks in advance.
aamar
Re: Insufficient memory by PSS analysis
Reply #1 - Sep 6th, 2006, 6:56am
