Aug 22nd, 2024, 11:23pm
Analog Fault Model (Read 1536 times)
rahul_iitkgpvlsi
IIT Kgp
Analog Fault Model
Sep 06th, 2006, 10:39pm
Could you please give me details idea about analog fault model? In DFT for digital system,there are few specific fault model.But for analog, I don't think there is any specific fault model.If you have any idea regarding this,please come up with your idea.
Rahul
View Profile rahul_iitkgpvlsi tubai369   IP Logged
rf-design
Reiner Franke
Re: Analog Fault Model
Reply #1 - Sep 8th, 2006, 12:36pm
The fault models are similar. These are device orientied. Two terminal devices have opens and shorts. Three terminals have typical 2 shorts and three opens. The analysis bench is typical a netlist processing script which exchange one device by a faulty device model. Then the simulation result is compared to a test reference. If the fault could be observed the simulation test having coverage of this instance.
