Jul 18th, 2024, 2:21am
vccs (Read 180 times)
jhon
vccs
Sep 08th, 2006, 8:11am
Hi guys,
I would like to implement a small signa equivalent circuit of a transistor with Spectre....
At the moment the main problem is the voltage controlled current source,  :'(
I am defining it as follows:
source (gi gs di si) vccs gm=GM
but I would like to define also the delay time (i.e. tau, gm*exp(-jwtau)).
Do you know how I can define this delay time?????  :-?
Thank u!!!!!!!!!
Re: vccs
Reply #1 - Sep 8th, 2006, 8:32am
Combine the vccs with a delay line (spectre -h delay).
jhon
Re: vccs
Reply #2 - Sep 8th, 2006, 9:30am
Hey Spectre,
Thanks a lot for your feedback....
But I am completely new with Spectre,
how may I combine these functions?
I mean...which is the syntaxis??? Huh
John O Donovan
San Jose, CA
Re: vccs
Reply #3 - Sep 8th, 2006, 5:04pm
The syntax for all Spectre devices is the same. The get help on the delay device, use "spectre -h delay". Incidently the vccs device also has a "td" parameter which will do what you want, i.e.
 source (gi gs di si) vccs gm=GM td=TAU
Again "spectre -h vccs" explains this.
 John
jhon
Re: vccs
Reply #4 - Sep 9th, 2006, 3:01am
perfect... Wink
thank u!!!!!
