John O Donovan
San Jose, CA
The syntax for all Spectre devices is the same. The get help on the delay device, use "spectre -h delay". Incidently the vccs device also has a "td" parameter which will do what you want, i.e.
source (gi gs di si) vccs gm=GM td=TAU
Again "spectre -h vccs" explains this.
Regards, John
