Aug 16th, 2024, 12:22pm
the peak di/dt issue in dsign phase (Read 1775 times)
dandelion
Sep 10th, 2006, 6:48pm
For my TTL/CMOS buffer design, i found the peak di/dt is high up to ~500MA/s in simulation. Here MA is mega ampere. I know,it will cause the serious vdd/gnd bounce.But we know, in actual conditions, it is not so pessimistic.Many solutions will be used to improve it, e.g, the bypass cap in PCB bord.
I want to know, is 500MA/s current change rate be tolerable in simulation phase?
Will it cause any EMI concern?
Can anyone shed some light on it?
Re: the peak di/dt issue in dsign phase
Reply #1 - Sep 11th, 2006, 10:20pm
You might want to start including some of the parasitic RLC elements. It sounds like you may have some ideal elements that are giving you some misleading results.
