![](https://designers-guide.org/forum/avatars/fredflinstone.gif)
Best Design Tool = Capable Designers
Two immediate things come to mind here:
Capacitance accuracy - MOS Caps are nonlinear, suggest you go to a MIM type that exhibits more linearity. Sometimes this is also poorly modeled.
Current Accuracy - How is your current being defined? Unless there is an external current reference, or some trim/adjustment, most internally defined current sources have an absolute value error that is pretty large.
Two good places to start. After that, you need to start looking at the min-max accuracy/tolerances of all the parts and pieces.
