Aug 22nd, 2024, 7:19pm
The accuracy of oscillator's frequency (Read 2448 times)
caosl_zju
Sep 10th, 2006, 11:32pm
hi,all
I need a 100Khz square wave oscillator.The measure of formerly designed one has a large departure to spec.It's architecture is composed of a current reference,a mosfet capacitor,a comparator.The deviation may be caused by current or mosfet capacitor.Could anyone tell me a better method to improve the oscillation frequency's accuracy? Thanks very very much.
Re: The accuracy of oscillator's frequency
Reply #1 - Sep 11th, 2006, 12:46am
Two immediate things come to mind here:
Capacitance accuracy - MOS Caps are nonlinear, suggest you go to a MIM type that exhibits more linearity. Sometimes this is also poorly modeled.
Current Accuracy - How is your current being defined? Unless there is an external current reference, or some trim/adjustment, most internally defined current sources have an absolute value error that is pretty large.
Two good places to start. After that, you need to start looking at the min-max accuracy/tolerances of all the parts and pieces.
caosl_zju
Reply #2 - Sep 11th, 2006, 1:44am
hi,loose-electron.
  Thanks a lot .It looks as if that  the current is a troublesome problem except for trimming.but the cost will be increase.
Reply #3 - Sep 11th, 2006, 10:17pm
If you want an accurate current (without trim) use an external reference resistor.
Bandgap drives a V to I converter, which uses an external reference resistance.
There are gobs of chips out there that have been doing this for years.
