Quote:Are you doing a device model
Yes, i'm doing a MOSFET model similar to the one of MOS11.
Quote:What simulator are you going to run it in? The question about a compiler is probably not relevant - you don't really want to see the C code produced by the compiler, you want the compiled object to run in your simulator. Spectre comes with a compiler; last I heard, Eldo's compiler required a special license.
At this point of time, i have access to Cadence's product. Therefore, i assume i will run in spectre. But, before i finished all my coding(/my model), i would like to view some of the (intermediate)results for debugging...like checking whether the internal function behaviors are right or not....
I'm looking some software/tool that allows me to probe the internal function behavior for debugging purposes. I have all the equations ready in Matlab, but now need to code it in Verilog-A so that i can connect to simulator.
I should check the ADMS up, till then...Thanks....
