Jul 16th, 2024, 12:31pm
Digital gates in Verilog-A (Read 6659 times)
cr
Oct 12th, 2006, 6:57pm
Hi All,
I'm currently tasked with getting a few control gates working in our Verilog-A system simulations and unfortunately AMS is not currently an option. I have a strong Verilog-D background, have read most of Ken's book and have looked at a lot of the online models and the ones supplied by Cadence. What I am having a problem with is understanding why the Cadence models are written the way they are. The following pattern is used to detect the input transitions:
   logic_input = V(vlogic_in) > vthreshold;
   @(cross(V(vlogic_in) – vthreshold, 1)) logic_input = 1;
   @(cross(V(vlogic_in) – vthreshold, -1)) logic_input = 0;
What I don't understand is why the “logic_input” (an integer) is being set by both the conditional and the event? I do understand that you want to use some form of cross to more accurately detect transitions.
Any help in expanding my understanding is most appreciated!
C.
« Last Edit: Oct 13th, 2006, 9:03am by cr »
Re: Digital gates in Verilog-A
Reply #1 - Oct 13th, 2006, 12:00am
The first line is needed to assure the logic is implemented and works proberly for time-domain analyses (such as DC) where the @cross() statements are not active.
But I'm with you, I see no purpose behind again assiging them in the cross statements.
cr
Reply #2 - Oct 13th, 2006, 9:05am
Thanks Ken!
I noticed I miss typed the last line. It has now been fix. Dang cut and paste. My plan for implementing this was:
   @(cross(V(vlogic_in) – vthreshold, 0))
Since you only need to have one cross statement on whatever watch list is used by the simulator and it isn't looking for a particular type of transition I'm assuming it will create the crossing event faster and if nothing else it's fewer lines/more readable.
C.
Reply #3 - Oct 13th, 2006, 11:58am
Look good. Alternatively you could write it using above() rather than cross().
cr
Reply #4 - Oct 13th, 2006, 9:17pm
Good suggestion! I looked at both and I think above() reads a bit better for combinational logic. To me it's slightly easier to see what is actually going on (fewer parallel paths). Of course I'm still using some crosses for the FF and latch models. Also, while I realize it's easy to fake a below() function, having one sure would make active low inputs easier to spot.
C.
jbdavid
Reply #5 - Oct 14th, 2006, 2:11am
'above' wasn't an option when those were written..
but there has been little maintenance on those models over the years.. ...
if it ain't broke..
Jonathan
jbdavid
cr
Reply #6 - Oct 15th, 2006, 8:45pm
Understood, and I agree if they are working fine there is really no need to mess with them. Though a couple of examples using more modern constructs would always be helpful. My question was simply to verify there was not a defect in my mental model of how things work since the two assignments appeared to be redundant (confirmed by Ken). Keep in mind my first look at Verilog-A was early last week. My past experience is helping me be a quick study, but I still have a ways to go before I have mastered both the syntax and more importantly the semantics.
C.
cr
Reply #7 - Oct 18th, 2006, 10:20am
Here's a short update. After actually trying after() and reading a bit more, it turned out to be almost useless for what I was trying to do. The problem is that while it does provide the level sensitivity that is need for the initial simulation step it is only sensitive to the rising edge. That killed it for any combinational logic. I was initially using it on the asynchronous inputs of latches and flip-flops, but I removed those yesterday as I consolidated all the initialization code into the inital_step block. To me this makes it easier to understand how the model variables are being initialized since all the initialization code is in one place.
For those that are curious I did use the pattern in my second post for all the combinational logic.
Thanks for the comments.
C.
