Aug 18th, 2024, 12:24am
How to reduce prescalar noise? (Read 1818 times)
ezbentley
Sep 25th, 2006, 11:16am
What are some techniques to reduce the noise contributed by the frequency divider? I heard one way is "re-timing." How does it mean?
rf-design
Reiner Franke
Re: How to reduce prescalar noise?
Reply #1 - Sep 26th, 2006, 12:59pm
If you use an asynchronuous divider the phase jitter of the individula stages accumulate. Typical in CML there is also current scaling for the stages operating at lower frequencies. These contribute more to the output jitter of the critical edge. A way to avoid this accumulation is to use a noise optimized register to resynchronize the last noisy edge with the input clock.
Be careful with delay issues! If the noisy edge to synchronize is in the critical register window you can have undefined output states.
