Jul 19th, 2024, 2:22pm
High speed OTA (Read 4538 times)
chase.ng
penang/malaysia
High speed OTA
Sep 27th, 2006, 5:26am
It appears to me that most high speed CMOS OTA like the one utilized in pipeline ADC (sampling rate > 100MHz) are usually implemented as single stage OTA such as folder cascode coupled with other tricks like gain boost, rather than 2-stage. My understanding is that compensation cap in the 2 stage structure will slow down the speed regardless of what kind of compensation is being used and therefore more power needs to be burned to increase the speed. I try to design some high speed 2 stage OTA before, but I found that at some point, burning more power will not really increase the speed without compromising the stability, I think that has something to do with the parasitic capacitance.
Is anybody here experienced in designing high speed OTA? Especially 2 stage OTA. I would really appreciate if someone can share his/her experience on the design, such as what is limitation? How fast (in terms of gain bandwidth product or unity gain frequency) can an OTA given a particular process?
Thanks and Regards,
chase
Chase
View Profile chase.ng   IP Logged
Sarig
Re: High speed OTA
Reply #1 - Sep 29th, 2006, 2:04pm
First you need to look at output Cap. and Gain which you need, maybe 1 stage is fine for you ?
Mainly your output Cap will limit you for a given supply current. we are missing here numbers.
Sarig
chase.ng
penang/malaysia
Re: High speed OTA
Reply #2 - Oct 1st, 2006, 6:03pm
My concern is that single stage normally will not able to provide large voltage swing. I would think it is very crucial to increase signal to noise ratio especially when supply is becoming lower and lower.
chase
Chase
Faisal
Re: High speed OTA
Reply #3 - Oct 2nd, 2006, 4:02am
Well, you need to first put some specifications down. What supply voltage you are on, what speed you are looking at etc ? Output swing, Gain etc will decide btw 1-stage or 2-stage. In 2-stage you can use a class-AB output stage for improved slew rate.
Hope this helps.
KR,
Faisal
Re: High speed OTA
Reply #4 - Oct 2nd, 2006, 7:11am
Hi Faisal,
Would you give me an example, a paper, a patent, or any literature else, to show an amplifier with class-AB output stage that is used in a pipelined ADC? It is interesting.
Best regards,
Yawei
Faisal
Re: High speed OTA
Reply #5 - Oct 2nd, 2006, 11:49am
A 1.8-V digital-audio sigma-delta modulator in 0.8-μm CMOS from Rabii, S.; Wooley, B.A.;
A low-voltage low-power fast-settling operational amplifier for use in high-speed high-resolution pipelined A/D converters: Lotfi, R.; Shoaei, O.;
KR,
Faisal
Re: High speed OTA
Reply #6 - Oct 6th, 2006, 2:59pm
Guys:
Two comments -
1. Google it - a lot of folks post their papers online.
2. Get a copy of the IEEE JSSC and search that database. If you are a memeber you can get the whole thing on DVD for about $80 USD.
jerry
