Jul 20th, 2024, 12:35am
Noise Figure based on rmsnoise (Read 1692 times)
ezencir
Irvine, CA
Sep 27th, 2006, 9:52am
Hello All,
NF equation says
NF=10*log10(Vn,out**2/(A**2*4kTRs)) where A is the voltage gain from source to output, and Rs is the source impedance.
How can I get Vn,out**2 term from rmsNoise function of Cadence?
In other words, what is the exact Analog Design Environment output expression to calculate NF?
Thanks for the feedback.
ACWWong
Oxford, UK
Re: Noise Figure based on rmsnoise
Reply #1 - Sep 27th, 2006, 11:53am
you should use the "add to outputs button" to get the expression under the results->direct plot-> main form of the ADE GUI.
So output squared rms noise is:
getData("out" ?result "noise")**2
likewise the noise figure is:
getData("NF" ?result "noise")
the use of the rmsNoise funtion integrated the noise over a certain bandwidth. Normally one plots NF(f) using Av(f) and vn(f) so the rmsNoise calculator function might not be that useful.
