Jul 19th, 2024, 12:16am
about programmable gain amplifier design (Read 3934 times)
mists
Sep 29th, 2006, 2:48am
I want to design a circuit that the input signal will minus a offset signal and then amplified, the gain is from 1~8, step is 1. I use the following circuit, as you know
Vout=(Voff-Vin)*R2/R1,
I want to adjust r2's value to get different gain, but I found it is hard to design and optimize the amplifier because when we set  different gain, the feedback factor of the amplifier also change, so it is hard to design and optimize the amplifier for high speed. the speed is about 60M.
then how to design this function circuit or how to design the ampliifier, wish your comment and help, thanks!
« Last Edit: Sep 29th, 2006, 4:26am by mists »
Re: about programmable gain amplifier design
Reply #1 - Sep 30th, 2006, 8:20am
How do you define "the speed is 60M"? Is it Ft of the amplifier or the frequency of the input signal?
It is difficult because the amplifier doesn't preserve a constant phase margin when the feedback factor varies. Right? However, if the amplifier is used to track a step input signal, you just make the phase margin greater than 60 degree. It's OK.
Best regards,
Yawei
Reply #2 - Oct 6th, 2006, 3:04pm
60 MHz through an op-amp?
Um... well yes, but you are getting into a region where you may want to stop using feedback amplifiers.
Also, another useful trick - optimize the amplifier for the maximum gain, and always use it at the maximum gain.
Insert swiched attenuators (resistors and switches) pre or post the amplifier (as needed) and you are done.
Jerry
andre75
Sunnyvale, CA
Reply #3 - Oct 6th, 2006, 4:41pm
The amplifier needs to be stable for the maximum feedback (minimum gain). It will autmatically be stable at higher gains due to the constant GBW product.
If your min gain is 1, the min Noise Gain for that amplifier will be 2.
You can run an ac simulation with the amplifier in a closed feedback loop (use one of the methods described in the Linear Technologies Switcher Cad Software - you can download it for free and the Examples are really good - Loopgain and Loopgain2).
Then make sure the amplifier shows at least 60dB PM with the min gain setting (this means pushing the second pole to about 2.2GBW).
The math gets pretty complex. Depending how fast your amplifier slews, it will go through 2 regions. Slewing and settling.
For a 60MHz signal you will have about 8.3ns to settle (awfully short).
Depending on the gain, the amplifier will enter the linear settling period at about Vout(final)-0.1V (for CMOS, rough number), which means you need to have maybe 5 times the internal time constant to wait for 0.1% accuracy.
Anyways, 60MHz seems a little bit too much. Consider the sizes of the resistors and the parasitic poles (at the input pins of the amplifier, coming from the resistor parasitic caps and the amplifier input). Those will add some additional phase shift.
RobG
Bozeman, MT
Reply #4 - Oct 18th, 2006, 9:07pm
A few things... use a current feedback amplifier if possible.
If not, try this, but I expect this will kill your noise and offset spec.
1) keep R2 constant.
2) put a resistor across the +/- terminals of the op-amp (call it R3).
3) vary R1 to get your gain.
As you decrease R1, the gain will lincrease.  Your bandwidth will remain constant until R1 ≈ R3/2.
What this does is create a gain of R2/(R1||(R3/2)), which is roughly constant until  R1 ≈ R3/2.
If your can't do one of the above, you can also change the compensation capacitance for each value of feedback resistor.
rg
