mists
I want to design a circuit that the input signal will minus a offset signal and then amplified, the gain is from 1~8, step is 1. I use the following circuit, as you know Vout=(Voff-Vin)*R2/R1, I want to adjust r2's value to get different gain, but I found it is hard to design and optimize the amplifier because when we set different gain, the feedback factor of the amplifier also change, so it is hard to design and optimize the amplifier for high speed. the speed is about 60M.
then how to design this function circuit or how to design the ampliifier, wish your comment and help, thanks!
