I've done this kind of thing in the past by using a chain of inverters with the "supply" of the inverters controlled by a regulator. This regulated supply is then controlled to ensure that the chain of inverters represents once cycle of the clock - in other words, a delay locked loop, as has been suggested before.
Not sure why you object to using inverters for this - it's simple, and works...
