Sep 17th, 2024, 12:22pm
3 phase non-overlapping clock phase generation (Read 9080 times)
Faisal
Oct 02nd, 2006, 2:43am
I am looking for some references for 3 phase non-overlapping clock phase generation.
Faisal
Re: 3 phase non-overlapping clock phase generation
Reply #1 - Oct 2nd, 2006, 8:29am
Hi Faisal,
Are the 3 phases equal? If so, I think a DLL is required.
Yawei
Faisal
Reply #2 - Oct 2nd, 2006, 11:24am
Hi.
The two phases are equal in time. The third phase is much smaller than the two phases.
Faisal
Reply #3 - Oct 3rd, 2006, 6:59am
Hi Faisal,
If the third phase is much smaller than the others, it can be achieved by increaseing the delay of both paths. Then get two small phases in the nonoverlapping time of a convetional non-overlapping clock generator. En, it becomes a 4 phase clock. Sad However, if the timing budget is not very tight, you just omit one of the small phases.
Best regards,
Yawei
Faisal
Reply #4 - Oct 3rd, 2006, 12:40pm
Hi Yawei,
Thanks for the reply. Any ideas on the delay element/line implementation. I do not like using inverter as a delay element. I am looking for a design, which gives me more control on the delay, could be voltage controlled/ digital controlled.
Papers/Reference ??
Faisal
Reply #5 - Oct 5th, 2006, 9:08am
Faisal,
I don't like using inverter as a delay element, too. However, it is easy. Smiley
Sure you could use something voltage/digital controlled if you need a precise third phase. There are many papers/reference about delay cell design.
Yawei
Reply #6 - Oct 6th, 2006, 3:23pm
take a look in the IEEE JSSC on the subject of VCO's that use Ring Oscillators. The delay element there are applicible here.
Jerry
Reply #7 - Oct 28th, 2006, 7:33am
I've done this kind of thing in the past by using a chain of inverters with the "supply" of the inverters controlled by a regulator. This regulated supply is then controlled to ensure that the chain of inverters represents once cycle of the clock - in other words, a delay locked loop, as has been suggested before.
Not sure why you object to using inverters for this - it's simple, and works...
Reply #8 - Oct 28th, 2006, 7:35am
Of course, if you have a higher frequency clock, you can divide it to obtain your different phases... and then use conventional small delays to provide the non-overlap.
