Jul 19th, 2024, 2:28am
stability of the cross-coupled transistor circuit (Read 2945 times)
rf_man
Oct 11th, 2006, 7:34am
Shall the stability of cross-coupled transistor circuit be checked? since this circuit is a positive feedback circuit, it's always instable? Such cross-coupled transistor circuit is often found in many applications, such as frequency dividers, shall a designer ensure that cross-coupled transistor circuit stable? It's really confusing
Re: stability of the cross-coupled transistor circ
Reply #1 - Oct 11th, 2006, 10:32pm
as in a cross coupled load?
or as in a cross coupled latch?
You might want to clarify a bit please, a simple schematic would be great!
tnx,
Jerry
jbdavid
Reply #2 - Oct 11th, 2006, 10:57pm
How much drive is required to switch them? that might be a good measure of the stability.. if the number drops too close to zero, noise might do the trick!
jbdavid
rf_man
Reply #3 - Oct 12th, 2006, 12:27am
Thank you for your reply!
I want to know for the following situations.
1. as load of two emitter followers, i.e. the cross-coupled pair is connected to the emitters of the emitter followers.
2. as latch in a D-latch, i.e. the cross-coupled pair connected with a differential pair.
how do you think about the stability issue for the above 2 cases?
