Jul 16th, 2024, 12:35pm
Diva LVS Options (Read 98 times)
alp
Diva LVS Options
Oct 11th, 2006, 9:03pm
Hi everyone,
What do the following options represent in Diva LVS check window of Cadence?
Rewiring
Device Fixing
Create Cross Reference
Terminals
When should/shouldn't I check them?
i.e. any risks if i anyhow check or uncheck all of them? Undecided
thanks,
alp..
ACWWong
Oxford, UK
Re: Diva LVS Options
Reply #1 - Oct 13th, 2006, 3:25am
you should find the answers in the diva reference manual...
but as i recall:
Rewiring: means the LVS "rewires" errors it enconunters to complete the LVS. Its better to have this ticked. As a result you often get LVS layout errors of "merged net" which denotes the tool had to merge nets in the layout to match the schematic... ie you forgot to connect a net in the layout
Device fixing: stops the tool from rationalising devices or allowing permute rules on circuit components you fix. Not needed to tick unless you which to preserve for layout things like parallel/series resistors, exact matching of MOS no.fingers/wtotal etc.
Create Cross Reference: you create a cross reference between schematic and layout for a device or net. not
needed unless you have problems the tool can't resolve, typically involving circuits with loads of symmetry and loads of identical circuit paths...
Terminals: terminals (pins) are used as correspondance points between schematic and layout. If you names the pins in layout and schematic the same, then you should have this ticked.
cheers
aw
