Jul 18th, 2024, 1:24pm
   Porting systems from one technology (Read 2341 times)
kamesh419
Oct 13th, 2006, 8:09am
Dear all,
I would like to know what all aspects one has to keep in mind when porting a system (in my case an SRAM which is in the layout level) from one technology to another (lower technology).
Thanks and Regards,
Kamesh.
Truth lies everywhere and partially even with the error.
bharat
Re:     Porting systems from one technology
Reply #1 - Oct 14th, 2006, 5:28am
These are generic thumb rules for any circuit and hold good for SRAM also
1. If the same devices available in the new technology, the aspect ratios are kept same. In the other words, shrink the geometry by the shrink   factor. Change the mult factor of the devices if the new technology has limitations in max width.
2. For the devices which are there in old technology but the new technology's foundry doesn't have it, you need to look for closest device characterstics (through simulation) and compare the device strength with the desired aspect ratio. Extend it for resistances, metals etc.
kamesh419
Reply #2 - Oct 18th, 2006, 5:05am
Thanks a lot Bharat for the information. Very useful.
/Kamesh.
