ACWWong
do a noise analysis. the accuarcy is dependant on the PDK model files, but is usually very good at non-RF frequencies (< a few hundred MHz). doing an ac analysis as well to confirm the small signal response is also worthwhile to ensure your operating point for you small signal sweeps (ac, noise) is correct.
