jeetchu
I encountered problem for OIP3 and OP1dB with my circuit.
the circuit is just a RF amplifier.After get proper input and output impedance match,i use pss to get OP1dB and pss+pac to get OIP3.the result is OP1dB is 12dBm,however,OIP3 is only 6dBm. the sweep range for OIP3 is -40 to -20dBm, and the 3rd linear region is ok.i wonder why the OIP3 is so small.Would someone like to give me some help or suggestion? Thanks.
