Jul 18th, 2024, 9:54pm
ac simulation with sc cmfb in an telescopic opamp (Read 2212 times)
zychang
Ireland
Oct 19th, 2006, 7:24am
I just have a little problem doing the ac analysis of the opamp. It is a fully differential telescopic opamp with a switched-capacitor CMFB(common mode feedback) circuit.  At first, I simulate the opamp with a sort of ideal CMFB and got the gain and UGB I want. Then, I put in the SC CMFB and did a tran analysis to see how many clock cycles the output CM needed to settle. After finishing both steps, I was trying to see how much gain and UGB I got with this SC CMFB. But here is the thing, how could I do the AC analysis with the output CM needs to settle in some clock cycles? Is there anyone having done this before could give me some advice? thanks in advance.
Mike
Re: ac simulation with sc cmfb in an telescopic op
Reply #1 - Oct 19th, 2006, 5:28pm
Use the PAC analysis of SpectreRF.
