Aug 16th, 2024, 12:18am
mixer linearity (Read 2643 times)
sivacha
India
mixer linearity
Oct 20th, 2006, 9:48pm
can u suggest the best way to improve the linearity of a folded mixer??
by doing source degeneration the noise figure is increasing.
i have very tight constraints on noise figure and linearity.
are these inter-related??
thank you.......
aaron_do
Re: mixer linearity
Reply #1 - Oct 20th, 2006, 11:50pm
A folded mixer is just an amplifier plus a switching stage. Source degeneration will improve the amplifier linearity at the cost of noise figure and gain. You should be able to use any of the typical methods to improve your amplifier's linearity such as multiple gated transistors. Or you could use a low noise amplifier...
Another method i've seen is to use a current mode mixer followed by an IF transimpedance amplifier.
hope that helps
Aaron
ACWWong
Oxford, UK
Re: mixer linearity
Reply #2 - Oct 21st, 2006, 1:57pm
sivacha wrote on Oct 20th, 2006, 9:48pm:
generally yes, more linear means less gain & more noise... as Aaron suggested you can try different toplogies/circuit system lineup, but the usual method to break this catch22 is to increase power ...
