Jul 21st, 2024, 6:17pm
What these Spectre Warnings have impact on results (Read 1063 times)
kiran123
Oct 24th, 2006, 2:55am
Hi Experts,
     I have question while running spectre using MDL i am getting below warnings i understand what these mean but not aware how this impact my simulation accuracy.
****************************LIST of WARNINGS *******************************************
a) I0.M38: Vgd has exceeded the oxide breakdown voltage of `vbox' = 2.27 V.
b) I0.M43: Vgs has exceeded the oxide breakdown voltage of `vbox' = 3.5667 V.
c) I0.M43: Device leaves the gate-source oxide breakdown region.
d) I0.M7: Device leaves the gate-drain oxide breakdown region.
e) I0.M31: The bulk-drain junction current exceeds `imax'.
f)  I0.M31: The bulk-drain junction current no longer exceeds `imax'.
Can you please let me know is there any option to specify to improve the accuracy while maintaining these warnings
thank you
kiran
ACWWong
Oxford, UK
Re: What these Spectre Warnings have impact on res
Reply #1 - Oct 24th, 2006, 3:42am
what i would do would to investigate what is going on in the circuit first, then try things like putting in some supply impedance or similar "lossy" real artifacts to your netlist in an attempt to tame these momentary limit overshoots which arise in warnings....
probably a naughty thing to do would be to increase the limits a bit to see if helps...
try spectre -h param_limits or look it up in the manual....
bernd
Munich/Germany
Reply #2 - Oct 24th, 2006, 5:16am
imelt (imax) and vbox are bsim3v3 & bsim4 model parameter
Junction diode model parameters:
103     imelt=`imax' A    Explosion current.
104     ijth (A)          Alias to `imelt'.
Operating region warning control parameters:
222     vbox=1e9*tox V    Oxide breakdown voltage.
See also one of my previous postings:
http://www.designers-guide.org/Forum/YaBB.pl?num=1132058634/1#1
Bernd
Just another lonesome cad guy
Reply #3 - Oct 24th, 2006, 7:29am
The vbox message is just a warning to you that the voltage across the oxide is too high to be maintained without damage given the thickness of the oxide. The actual damage is not modeled, so the simulation results are unaffected by the presence of this message.
The same is true for imax. Imax is a user specified limit on the junction current, that when exceeded produces a warning message but does not change the behavior of the device model. If, however, you go further and exceed imelt, then you have exceeded the limits of the model and the results will be incorrect.
Reply #4 - Oct 24th, 2006, 10:13am
bernd wrote on Oct 24th, 2006, 5:16am:
Per the Compact Model Council's evolving policy on standard models, these are *not* official BSIM3/4 model parameters; they are extra parameters in Cadence's implementation of these models (as well as, I presume, other MOS models).
