The vbox message is just a warning to you that the voltage across the oxide is too high to be maintained without damage given the thickness of the oxide. The actual damage is not modeled, so the simulation results are unaffected by the presence of this message.
The same is true for imax. Imax is a user specified limit on the junction current, that when exceeded produces a warning message but does not change the behavior of the device model. If, however, you go further and exceed imelt, then you have exceeded the limits of the model and the results will be incorrect.
