Jul 16th, 2024, 1:33pm
coffee maker problem (Read 4250 times)
lanun_kampung
Oct 26th, 2006, 8:46am
hi guys..
i'm a 2nd year electronics n electrical student at UTP..
i need to build a coffee maker using verilog HDL.start from water boiling- mixing -stir -brew...any1 can help.??? Undecided
your help is appreciated Smiley
bernd
Munich/Germany
Re: coffee maker problem
Reply #1 - Oct 26th, 2006, 9:19am
Sounds like a Finite State Machine
http://en.wikipedia.org/wiki/Finite_state_machine
The most common student exercise for that is the  traffic light, maybe this
may help you as a starting point.
http://www.cs.technion.ac.il/~cs236346/tlc.v
(Just found through Google, not tested)
Bernd
Just another lonesome cad guy
lanun_kampung
Reply #2 - Nov 9th, 2006, 8:37am
tq...
this is my program. i'm using quartusII
//timer
module clock_div (Q0,CLK,coffeetype);
     input CLK;
     input coffeetype;
     output Q0;
     reg CLKdiv;
     reg [23:0] i;
     initial
           begin
                 i=0; CLKdiv=1'b0;
     always @ (negedge CLK)
     begin
                 if(coffeetype)
                 begin
                       if (i<24'b111111111111111111111111) i=i+1;
                       else begin
                                   i=0; CLKdiv=~CLKdiv;
                 else
                 begin
                       if (i<24'b110000000001000111101100) i=i+1;
                       else begin
     assign Q0=CLKdiv;
//water sensor
module water_sensor (waterstatus,warninglight,CLK, waterlevel);
input waterlevel,CLK;
output waterstatus,warninglight;
reg waterstatus,warninglight;
     always@(posedge CLK)
           if (waterlevel==1)
                 waterstatus =1'b1;      //boilerNotEmpty
           else
                 waterstatus =1'b0;//boilerEmpty
           if (waterlevel==1)
                 warninglight = 1'b0;
           else
                 warninglight = 1'b1;
//warmerplate sensor and valve pressure
module plate_sensorAndvalve_pressure (openclose,platestatus,CLK, pot);
input pot, CLK;
output openclose,platestatus;
reg openclose,platestatus;
           if (pot==0)
                 platestatus = 1'b0;      //turns off plate warmer
           else
                 platestatus = 1'b1; //restart plate warmer
           if (pot==0)
                 openclose = 1'b1;      //open valve to stop water flow
           else
                 openclose = 1'b0;      //close valve to start water flow
//mixture sensor
module mix_sensor (mixstatus,warninglight1,mixsense);
input mixsense;
output mixstatus,warninglight1;
reg mixstatus,warninglight1;
     always @ (mixsense)
           case(mixsense)
           1'b0 : mixstatus = 1'b0; // indicate that there are no mixture in the container
           1'b1 : mixstatus = 1'b1; // indicate that there are mixture in the container
           endcase
     always @ (mixsense)
           case(mixsense)
           1'b0 : warninglight1 = 1'b1; // turn on mixture-warning light for error
           1'b1 : warninglight1 = 1'b0; // mixture-warning light is off if there are mixture in container
           endcase
//main coffee maker program
module coffee_maker(dispenserfilter,Q0,boiler,warmerplate,timer,mixcontainer,mixstatus,
warninglight1,waterstatus,platestatus,valve,Button,Setclock,CLK,pot,waterlevel,w
arninglight,mixsense,coffeetype);
input Button,Setclock,CLK,pot,waterlevel,mixsense,coffeetype;
output dispenserfilter,Q0,boiler,warmerplate,mixcontainer,waterstatus,platestatus,valve
,warninglight,mixstatus,warninglight1;
output [4:0]timer;
wire START;
reg [4:0] timer;
reg mixdispenser,boiltimer,timingprocess;
     assign START =  (Button||Setclock)&& timingprocess;
//instantiate water sensor
water_sensor      WS(waterstatus,warninglight,CLK, waterlevel);
//instantiate plate sensor and valve pressure
plate_sensorAndvalve_pressure      PSVP(valve,platestatus,CLK, pot);
//instantiate mixture sensor
mix_sensor            MS (mixstatus,warninglight1,mixsense);
     assign      boiler = START && waterstatus && mixstatus && boiltimer ;          // to make boiler heater turn on or off
     assign      #(100) warmerplate = START && platestatus && mixstatus ;            // to make plate heater turn on or off
     assign  #(200) mixcontainer = boiler && warmerplate ;                        // to make mixute container open or close
     assign      dispenserfilter = START && mixdispenser;
//instantiate timer
clock_div      CD(Q0,CLK, coffeetype);
     always@(posedge Q0)
           begin
                 timer=timer+4'b0001;
     always @(timer)
     begin
     case(timer)
           4'b0101: begin mixdispenser=1'b1; end
           4'b0110: begin mixdispenser=1'b1; end
           4'b0111: begin mixdispenser=1'b1; end
           default: begin mixdispenser=1'b0;end
     endcase
     always @(timer)
     begin
     case(timer)
           4'b0000: begin boiltimer=1'b1; end
           4'b0001: begin boiltimer=1'b1; end
           4'b0010: begin boiltimer=1'b1; end
           4'b0011: begin boiltimer=1'b1; end
           4'b0100: begin boiltimer=1'b1; end
           4'b0101: begin boiltimer=1'b1; end
           4'b0110: begin boiltimer=1'b1; end
           4'b0111: begin boiltimer=1'b1; end
           4'b1000: begin boiltimer=1'b1; end
           4'b1001: begin boiltimer=1'b1; end
           4'b1010: begin boiltimer=1'b1; end
           4'b1011: begin boiltimer=1'b1; end
           default: begin boiltimer=1'b0;end
     endcase
           always @(timer)
     begin
     case(timer)
           4'b0000: begin timingprocess=1'b1; end
           4'b0001: begin timingprocess=1'b1; end
           4'b0010: begin timingprocess=1'b1; end
           4'b0011: begin timingprocess=1'b1; end
           4'b0100: begin timingprocess=1'b1; end
           4'b0101: begin timingprocess=1'b1; end
           4'b0110: begin timingprocess=1'b1; end
           4'b0111: begin timingprocess=1'b1; end
           4'b1000: begin timingprocess=1'b1; end
           4'b1001: begin timingprocess=1'b1; end
           4'b1010: begin timingprocess=1'b1; end
           4'b1011: begin timingprocess=1'b1; end
           default: begin timingprocess=1'b0;end
     endcase
Reply #3 - Nov 10th, 2006, 5:07am
lanun_kampung wrote on Nov 9th, 2006, 8:37am:
		if (waterlevel==1)
		else
		if (waterlevel==1)
		else
Why is this done as two always blocks, rather than
		if (waterlevel==1) begin
		end else begin
I also might suggest a `define to keep track of the meanings, ie
`define BOILER_EMPTY 1'b0
`define BOILER_FULL 1'b1
-Geoffrey
