Jul 16th, 2024, 1:42pm
How to chose seed? (Read 4952 times)
neoflash
Mixed-Signal
Designer
How to chose seed?
Nov 15th, 2006, 10:20pm
How we choose the value of seed, of random number generator and how it affects?
Does this number play any role, besides specify a determistic start point? What if I chose seed=111?
neoflash
Mixed-Signal
Designer
Re: How to chose seed?
Reply #1 - Nov 15th, 2006, 10:21pm
attach the sample usage here: dT = jitter*$rdist_normal(seed,0,1);
Reply #2 - Nov 16th, 2006, 11:24am
As far as I know, it's just a start point in the sequence of pseudo-random numbers.
neoflash
Mixed-Signal
Designer
Reply #3 - Nov 16th, 2006, 5:03pm
I have attached one sample code from this website, why author chose seed=286, not other number?
module osc2 (out);
output out; voltage out;                  // output signal
parameter real freq=1 from (0:inf);            // output frequency
parameter real vl=-1;                        // high output voltage
parameter real vh=1;                        // low output voltage
parameter real tt=0.01/freq from (0:inf);      // transition time of output
parameter real jitter=0 from [0:0.1/freq);      // white period jitter
integer n, seed;
real next, dT;
analog begin
   @(initial_step) begin
     seed = 286;
     next = 0.5/freq + $abstime;
   @(timer(next)) begin
     n = !n;
     next = next + 0.5/freq + `M_SQRT1_2*dT;
   V(out) <+ transition(n ? vh : vl, 0, tt);
Reply #4 - Nov 16th, 2006, 7:20pm
It was a completely arbitrary choice. The only criteria I used was to use a different seed for each rdist function present in the system. If you give the same seed to two different rdist functions they will produce an identical sequence of random numbers.
Reply #5 - Nov 17th, 2006, 5:54am
Ken Kundert wrote on Nov 16th, 2006, 7:20pm:
By "two different rdist functions" Ken does not mean to say that $rdist_normal() and $rdist_uniform will give the same sequence of random numbers.  I am fairly sure he meant "give the same seed to two different calls of the same rdist function":
Modifying the example:
integer n, seed, seed2;
real next, dT, dT2;
analog begin
   seed = 286;
   seed2 = 286;
   n = !n;
   dT2 = jitter*$rdist_normal(seed2,0,1); // will have the same sequence of values as dT
dT2 will have the exact same sequence of random values as dT.  Also, seed and seed2 are changed by the $rdist function calls, and the sequence of their values will be the same.
I wonder: if you did
 rn1 = $rdist_normal(seed,0,1);
 rn2 = $rdist_uniform(seed2,-1,1);
will "seed" and "seed2" have the same sequence of (integer) values?  I guess you might or might not, since the LRM doesn't say.
-Geoffrey
