Aug 16th, 2024, 12:29pm
lo-rf isolation units (Read 3244 times)
sivacha
India
Oct 26th, 2006, 7:35pm
hi
i got a basic doubt regarding the units of lo-rf isolation.
in the specs for lo-rf isolation it is said that  XX dBVrms.
is it same as dB?? otherwise how to convert it into dBVrms??
Thanks a lot............
ACWWong
Oxford, UK
Re: lo-rf isolation units
Reply #1 - Oct 27th, 2006, 2:11am
dBVrms is dB in reference to 1 Vrms.
so if I have 1V amplitude sine wave signal (ie 1*cos(wt)),
then Vrms=1/sqrt(2)=0.707=-3dBVrms
lo-rf isolation is measured in straight dB (a unitless ratio) NOT dBVrms.
so if 1% of the LO voltage signal leaks to the RF port then one can say the LO to RF isolation is 40dB.
