Jun 30th, 2025, 5:46pm
from verilog-ams to verilog-hdl (Read 2211 times)
douglas
Oct 30th, 2006, 1:50am
Hello everybody,
time ago I used to make some verilogams codes. I've been inactive for a while and I've lost the practice.
now I'm trying to make a code, but totally digital (and using verilog hdl). the point with verilogams is that I'm trying to use something from it in my verilog-hdl code but I don't get it to work.
let me explain, its easy but I just can get it:
I have an ENABLE signal. when ENABLE goes high, an ouput clock must start (with a defined period). when enable goes down, this clock must goes to zero and stay at zero.
in verilog ams I could use the always block without a sensitivity list, for example:
always if (V(ENABLE)) Clk = ...
else Clk = ...
but in HDL I can't. the main problem Im having is stopping the Clk when Enable goes to zero.
if somebody can give me a tip or tell me what Im doing wrong I would be very grateful.
this is what Im doing:
reg Clk;
initial Clk = 0;
parameter delay = ...
parameter period = ...
always @(VLOEN)
   if (VLOEN==1) begin
      #(delay) Clk <= 1'b1; //some delay
      forever begin: COUNTING
         #(period * 0.5) Clk = ~Clk;
         if (VLOEN==0) disable COUNTING;
   end else if (VLOEN==0) Clk <= 1'b1;
I
Thanks in advance.
Eugene
Re: from verilog-ams to verilog-hdl
Reply #1 - Oct 30th, 2006, 7:59am
This may not do exactly what you want but it may give you some ideas.
always wait (ENABLE) #(0.5 * period) clk = ~clk;
wire GatedClk = clk & ENABLE;
The first line produces a clock only when ENABLE is high. The second line ensures the end result, GatedClk, is zero when ENABLE is zero.
I don't have my reference book with me or I'd check, but you may need an @ somewhere in the above lines.
I just checked. You don't need the @.
« Last Edit: Oct 30th, 2006, 2:58pm by Eugene »
