Aug 16th, 2024, 4:20pm
flicker noise of the down mixer (Read 3121 times)
sivacha
India
Oct 30th, 2006, 3:38am
hi
while designing the down mixer(active, folded mixer), iam facing a serious and well known difficulty with the flicker noise of the input switches.
Gain, noise figure and linearity are conflicting with each other.
Gain increases----> noise figure improved ------> linearity is lost.
Could you please suggest the good optimization for these??
Receiver:: Low IF type
Freq range of operation:: 2.4GHz
thank you...
aaron_do
Re: flicker noise of the down mixer
Reply #1 - Oct 30th, 2006, 8:45pm
How low is your IF? If it is above 1 MHz you should be able to avoid the flicker noise problem. Gain NF and Linearity always conflict. I suggest you optimize based on your receiver requirements (i.e. for what purpose?). You will need some idea of all the other stages performance also (channel select filter, VGA etc)
Aaron
sivacha
India
Reply #2 - Oct 30th, 2006, 9:48pm
aaron_do,
my IF is 1MHz.
this receiver is for BT2.0 Enhanced Data Rates.
my main concern is the flicker noise of the LO switches.
aaron_do
Reply #3 - Oct 31st, 2006, 4:50am
I don't really know anything about your system of the bluetooth 2.0 specs. I asked a question previously about system NF calculation and found this paper very helpful. Its posted in the link:
http://www.designers-guide.org/Forum/YaBB.pl?num=1157358393
based on your system specs you can estimate the required gain, NF and linearity.
hope it helps,
Aaron
