Jul 21st, 2024, 6:27am
simulation AC in AMS environment (Read 3105 times)
Pavel
Lausanne/Switzerland
Oct 31st, 2006, 8:37am
Hello
I have a filter described in Verilog-A.
How can I simulate it in AC.
Should I
- create symbol of this filter
- do shematic with it and some source
- call Analog Design Environment
or there is more simple way to proceed?
Thanks in advance.
Pavel.
ACWWong
Oxford, UK
Re: simulation AC in AMS environment
Reply #1 - Nov 1st, 2006, 7:02am
what you suggest is what i would do to setup an ac simulation of your verilogA code.
Reply #2 - Nov 2nd, 2006, 4:54am
I'd just write a spectre netlist by hand and run spectre from the command line ...
