Aug 16th, 2024, 10:16pm
Design of a Hartley Oscillator (Read 3388 times)
tripod2000
Nov 02nd, 2006, 2:46am
Hey all,
http://www.electronics-tutorials.com/oscillators/oscillator-basics.htm shows a Hartley oscillator and a Colpitts circuit.  There is a formula for finding a frequency of a Colpitts oscillator, but not a Hartley oscillator. I believe I need a Hartley oscillator for my design with a frequency of about 100kHz or about 1MHz. Could someone please suggest a formula to work out what values of componants I would need.
(I will have a variable capacitance.)
Thank You Wink
Re: Design of a Hartley Oscillator
Reply #1 - Nov 2nd, 2006, 7:52am
That web site uses small signal schematics with a large signal transistor in the middle of it. Also, the Hartley Colpitts oscillators don't get used a heck of a lot anymore. They tend to exist in one transistor designs from prior to 1965 or so.
Care to tell us a bit more about what you are trying to do and perhaps we can be of help?
thanks
Jerry
tripod2000
Reply #2 - Nov 2nd, 2006, 9:07am
I'm working on a control system like a Theremin. I want the oscillator frequency to change with a changing capacitance caused by a hand moving near an aerial. I figured on the Hartley because of the changing capacitance, the simplicity (cost being a factor in the design) and the feedback ration being constant seemed like a good idea.
Thank You.
