Aug 15th, 2024, 9:43am
Any PC based simulator for verilog AMS? (Read 1516 times)
neoflash
Mixed-Signal
Designer
Nov 03rd, 2006, 7:28pm
that kind of easy to get and free for starter?
Re: Any PC based simulator for verilog AMS?
Reply #1 - Nov 6th, 2006, 6:10am
I don't know of a full AMS simulator on PC, never mind a free one.
There is a sourceforge project "ADMS" that is a free, open-source Verilog-A only compiler; the developer is hooking it into the "ngspice" project.  Last I tried ADMS, there was a fair bit of hassle getting it all working.
Croaker
Reply #2 - Nov 21st, 2006, 8:32pm
Cry
Ken's paper on rapid top-down development with Verilog-A got me interested in this.  Is that methodology seeing much use?  It sounds like it would be a very quick and sensible way to design any non-trivial system.
jbdavid
Reply #3 - Dec 5th, 2006, 12:28am
I find its the fastest way for me..
jbd
jbdavid
Croaker
Reply #4 - Dec 5th, 2006, 10:19am
I was chatting with someone the other day that said at their company, it's more trouble to do the modeling than it is to jump into a transistor-level design.  I suspect this is only true is the design is already well-understood.
makelo
Hillsboro, OR
Reply #5 - Dec 6th, 2006, 7:06am
I can understand some designers thinking that it will take more time to build up a model than to simply jump into the transistor level.  After creating my first Verilog-A models I probably would have agreed.  But now that I have made a dozen or so models, I am more proficient and I  can make most models in under an hour which is far faster than any transistor circuit even if it is a simple diff pair with a hand full of specs.  The speed improvements in transient sims make AMS worth my time as well.
jbdavid
Reply #6 - Dec 8th, 2006, 11:18pm
As an update, there is a "free" simulator being developed as a Gnu project, led by Al Davis,
called GnuCap..  and he is moving it to use verilog-AMS as its NATIVE netlisting language..
the developement version has significant verilog-A support already.
While it will run on a PC - it should probably be running Linux.. but you might be able to run it on OS-X
http://www.gnucap.org
jbdavid
