Jul 16th, 2024, 1:55pm
Help Required for Veriloga Code of NAND gate (Read 8223 times)
junaidgill
Nov 24th, 2006, 11:35am
hello,
i am new to verilog-a and i am trying to write code for NAND gate. can anyone please help me to complete the behvior:
module NAND(in1, in2, out)
inout in1, in2;
output out;
electrical in1, in2, out;
parameter real vlogic_high = 3.5;
      //behvior of NAND GATE (i need help in this part)
i know that i should make use of @(cross(V(in1) - thresh, +1)) but i don't know the correct way.
Re: Help Required for Veriloga Code of NAND gate
Reply #1 - Nov 24th, 2006, 11:28pm
I just added some examples to the Verilog-AMS page. Take a look at http://www.designers-guide.org/VerilogAMS/functional-blocks/gates/gates.va.
junaidgill
Reply #2 - Nov 25th, 2006, 2:01am
thankyou very much Ken... those are really very helpful examples.....
Q8i
Reply #3 - Nov 28th, 2006, 6:28pm
Could you please add the same thing for Verilog AMS
i mean the and , or ,xor code for Verilog AMS If you don't mind
Reply #4 - Nov 29th, 2006, 12:13am
You can use the gates built-in to verilog when using Verilog-AMS.
But here is a behavioral model for a nand gate in verilog.
module mynand(in1, in2, out);
    input in1, in2;
    output out;
    assign out = ~(in1 & in2);
