Jul 16th, 2024, 1:52pm
verilogA error: ARnow: Undefined variable. (Read 5542 times)
xter
Nov 26th, 2006, 1:35pm
I have verilogA code that works when run in cadence spectre, but not in Hspice. It's included as a subckt.
I) In attempting to debug this problem, I commented out everything except the port definitions. The code is saved in a file called stage5.va:
`include "constants.vams"
`include "disciplines.vams"
module p_stage3_calib_model(VDD, Ph1, Ph2, Vrefp, Vrefn, Vip, Vin, D0M, D0L, S1, S0, Vop, Von);
     input Vip, Vin, Ph1, Ph2, Vrefp, Vrefn, VDD;
     output S1,
     output D0M, D0L;
     output Vop, Von;
endmodule;
II) The instantiation looks like this:
yistage5 vdd1 Q1 Q2 vrefp vrefn vo6_p vo6_n d5l d5m SwitchRefHiStg5 SwitchRefLoStg5 vo5_p vo5_n p_stage3_calib_model
III) In the .lis file, the error reads like this:
    During .hdl command processing, loading Verilog-A modules from
       './stage5.va'.
hsp-vacomp:
hsp-vacomp: Invoking the Verilog-A compiler for 'stage5.va'
** error **
During Verilog-A Device processing:
   Failed to compile the Verilog-A File,
       'stage5.va'.
IV) And at the command prompt, I get this error:
I am out of things to try to debug this problem. I thought if I slowly worked through the code, I could isolate this undefined variable, but I took out everything, and still get it.
Anyone have this error before?
Thanks!
Xter
Re: verilogA error: ARnow: Undefined variable.
Reply #1 - Nov 27th, 2006, 5:04am
Two things that jump out at me:
1) comma at the end of
   output S1,
should be a semicolon
2) In HSpice, VA instances must use 'x' (not 'y') as the first character of the instance name:
yistage5 vdd1 Q1 ...
Neither seems directly related to your problem, though.
xter
Reply #2 - Nov 27th, 2006, 8:31am
1. The comma is a typo from the paste. It is a semi-colan in code.
2. I did switch it to x.. as the instance name, same error. [The reason I left it as y... was because I netlisted in HspiceD in analog design environment, and used that netlist. I figured if it was automatically netlisted then there would be less errors introduced by me.]
Is there perhaps a version of hspice I should be using? I am currently using VY-2006.09 on a linux machine.
Xter
xter
Reply #3 - Nov 27th, 2006, 8:41am
I seem to have solved the problem. A co-worker mentioned the OS might matter, so I ran on a unix machine. This time I had more informative error messages and was able to easily debug.
Thanks for taking the time to reply to this message.
Cheers!
Xter
