jmedina
Florida
Be aware, when using ports in Spectre simulations, a real and imaginary impedance can be defined in the properties menu for the device. When a reactance is specified, this imaginary part is valid only when running small signal analyses like sp, ac, and noise. The reactance will give erroneous results if pss, psp, and pnoise analyses are run. We are reporting this to Cadence as an action item.
